where to buy a whindscreen rubber?
Old Jul 17, 2012 | 07:23 PM
antichrist's Avatar
I you do it yourself, of have someone other than a glass installer do it, be sure they use the right adhesive. A windscreen is considered a structural member and if you don't use the correct adhesive it won't withstand the impact it should in a rollover.
Old Jul 17, 2012 | 08:19 PM
collin Barrows's Avatar
I have state farm, and have been with them for about a year, and yes my agent told me this.
Old Jul 17, 2012 | 08:24 PM
I know I can get the glass cheap, but its the rubber thats going to cost me...
Old Jul 17, 2012 | 08:49 PM
It's always the rubber that gets you in trouble every time, dont use it properly and BAM!!!, you're in trouble.
Did you ask them why it needs to be inspected? I dont see why you still could not add glass coverage, but you would have to keep it after you added it until your renewal.
I also have State Farm, I never had to have anything inspected when I switched over to them a year or so ago.
Old Jul 18, 2012 | 06:30 AM
antichrist's Avatar
Probably a result of too many people doing what you suggested.
Old Jul 18, 2012 | 08:40 AM
alpinacsi's Avatar
Are you doing the replacement yourself? Is your rubber trim damaged? You do realize the windshield is glued in place and the trim can be reused if you are careful. Might be a good idea to have it removed/installed by someone that has done it before if you want to save the trim and the hundreds of dollars that replacement trim cost. If you do decide to DIY, make sure you use the proper adhesive as antichrist mentioned and also properly prep the glass and frame. I have about 10-12 caulk gun tubes of the sealer if you need any.
Old Jul 18, 2012 | 08:49 PM
Touche'
moorebl
Sep 2, 2013 10:01 AM
Raiderfan
Oct 10, 2007 07:36 AM
projekz
Sep 11, 2007 09:31 AM
bmwboy
Jun 17, 2007 09:27 PM
alex of minnesota
Nov 1, 2006 11:22 AM
