Whining sound from engine when idling
Old Nov 10, 2010 | 05:05 PM
tibyABv6's Avatar
Default Whining sound from engine when idling
My Disco1 has whining sound when idling ( it is a bit loud), sound goes away as soon as i press gas pedal...no whine when accelerating/driving.
Whine stars after car warms up...close to its full operation temp.
Does anyone had this problem or have some input on what can cause it?
Old Nov 10, 2010 | 06:30 PM
Spencerfitch's Avatar
Alternators Love To Whine, check it.
Old Nov 10, 2010 | 06:33 PM
okdiscoguy's Avatar
get a long screwdriver and put it on everything that has something spinning. You can hear the bearings through the handle. Be careful to not put it on anything actually spinning and do not get your hair caught in the belt.
A lady came into the shop yesterday with a bandage on the back of her head and a squealing belt..... it happens scalped her..
Old Nov 10, 2010 | 06:42 PM
tibyABv6's Avatar
ok i will try that, thanks
Old Nov 10, 2010 | 07:23 PM
Long Haul's Avatar
Check your vacume lines also. The motor will pull more vacume at idle and as soon as you open the throttle you tend to loose vacume causing the noise to go away
luxury1
Oct 5, 2021 05:09 PM
MyRoversNameIsCarl
Nov 25, 2014 10:07 AM
DiscoSlat
Dec 6, 2012 04:19 PM
G3
Freelander
May 11, 2007 11:03 AM
lenra
Dec 9, 2004 06:09 AM
