Whirring noise from headlight
Old Nov 19, 2012 | 09:23 AM
turpinator2012's Avatar
Default Whirring noise from headlight
I'm hearing a whirring noise from behind the passenger-side headlight when I switch them on, the headlights are also extremely dim despite fitting a new battery. Any ideas?
R-reg 300tdi, by the way!
Old Nov 19, 2012 | 09:29 AM
Michael M. Koch's Avatar
The extra amperage is straining a worn-out alternator?
Old Nov 19, 2012 | 10:10 AM
LH or RH drive? Measure battery volts on terminals of battery? Good connections all around? On NAS vehicles there is a 12 volt pump for cruise vacuum behind the left front head light.
Old Nov 19, 2012 | 09:15 PM
Your bulb is burnt out, the dim light you see is from the "city light".
Turn just your parking lights on and I bet the drivers side is the same brightness as the passenger side.
Old Nov 20, 2012 | 05:38 AM
ihscouts's Avatar
It could be they are turning to point at you, motor driven to look into your soul.
Keep a fire extinguisher in sight, see smoke, don't wait, pull pin and yell obscenities allot.
RedAustinIX
Feb 1, 2022 11:58 PM
xmc
Jan 12, 2012 08:12 PM
xmc
Jan 10, 2012 08:36 PM
slvrdisco01
Aug 19, 2009 05:15 PM
Disco Kiwi
Jan 31, 2006 07:13 PM
