Are window switch panels interchangeable D1-D2?
Old Feb 5, 2020 | 04:46 PM
Alpinewhitetaninterior's Avatar
Default Are window switch panels interchangeable D1-D2?
Hi guys, first post. Just had a simple question that I couldn't find the answer to with a search. It looks like the master window switch panel on the center console didn't change from the D1 to the D2, but I know that almost nothing is interchangeable between the two trucks, so I thought I would check before I order a wood grain panel from e-bay and find out it doesn't snap in place. Thanks for the help!
Old Feb 6, 2020 | 10:02 AM
WaltNYC's Avatar
they are the same part number.....but don't buy it off ebay, but it from me.
https://landroverforums.com/forum/pr...od-trim-94252/
It is sitting right here on my desk.
Old Feb 6, 2020 | 08:58 PM
Best4x4's Avatar
A lot of parts are interchangeable between a D1/D2
Old Feb 12, 2020 | 12:17 PM
Thanks guys. I sent a message about buying the switch plate. Looks great!
@Best4x4 Sorry I was using a previous thread for reference on the sweeping statement about swapable parts. Not a long thread, but the general consensus was that sunroof parts, rear-view mirrors, and a few other odds and ends where swapable. But that most of the other thing were not worth the time/energy. If you know anything else that snaps into a D1 without alteration I would love to know for future reference.
Thanks again!
P.S. If anyone sees a D1 roof rack for sale in the CA area drop me a line.
Old Feb 12, 2020 | 02:10 PM
Best4x4's Avatar
Dash, gauge cluster bezel, center dash bezel, misc dash parts, window regulators, window motors, (plugs are different but that normally unplugs directly at the motor itself unless aftermarket). Rear D2 AC slider= slider works on D1 main HVAC control head. Center console lid, window bezel, and I’m almost 90% sure a D2 steering wheel will work on a D2. Plenty of proof on the Grand Tour when they drove a brick, wood, and meat D1 which a few had D2 steering wheels but D1 wheels. SRS clock spring is the same so it should swap over.
Few other things swap back n forth enough you can make a hybrid D1 or hybrid D2 if you wanted to.
jimvw57
Oct 7, 2019 09:40 AM
LandIdaho
Feb 5, 2017 09:00 PM
Rock Sing
Jun 13, 2014 02:54 PM
justfred
Mar 12, 2007 10:20 PM
JBRIII
Dec 29, 2006 06:02 PM
