Wobble of death!!
Old Apr 27, 2015 | 09:29 AM
  #21
green-lantern's Avatar
My death wobble was the tie rod that goes into the pitman arm. It was just loose. I tightened the nut and all was well. It's nice when a fix is that simple.
Old Apr 27, 2015 | 09:58 AM
  #22
drowssap's Avatar
"My death wobble was the tie rod that goes into the pitman arm",
that would have been fun to find going down the highway
Old Apr 27, 2015 | 11:05 AM
  #23
It would get your blood pumping lol
Old Apr 27, 2015 | 11:38 AM
  #24
antichrist's Avatar
That's a serious issue, did you determine why the nut was loose? I've never seen a tie rod nut come loose on it's own.
Old Apr 27, 2015 | 01:28 PM
  #25
I'm assuming somebody had replaced it and didn't tighten it down correctly. I was trying to find the issue by having my son turn the wheel back and forth quickly. I thought the joint was worn out until I took a closer look and realized it was just loose. I just tightened it up and put the cotter pin back in. Maybe somebody backed the nut up too much to get the pin in?
Old Apr 27, 2015 | 01:31 PM
  #26
antichrist's Avatar
Sounds possible. Some have nylock nuts and if that was loose I'd use a new one (assuming no wear/damage to the rod end taper or drop arm). No issue reusing castellated nuts.
Old Apr 27, 2015 | 02:09 PM
  #27
Oh yeah, if it was nylon I would have ditched it and got a new one. I'm not a fan of nylon nuts on the suspension. I'd much rather deal with the cotter pin and castle nut.
Old Apr 27, 2015 | 02:26 PM
  #28
fishEH's Avatar
Ditto. The nylocks on the TRE's irritate me.
Old Apr 27, 2015 | 04:02 PM
  #29
jimvw57's Avatar
Nice!! a simple fix for once!!
Since I replaced the parts on the drivers side of the axle, everything settled down and runs right!! still have to replace the shock which is on order, and take care of the swivel ball leak on the pass side, but at least it is not a threat on the road!
Rover Chris
May 23, 2015 02:13 AM
Rover Chris
Sep 25, 2010 09:55 PM
blaze98
Sep 21, 2010 07:14 PM
mrcrptguy
Apr 9, 2009 06:02 AM
pelias
Sep 8, 2008 09:47 PM
