"M" and "S" lights started blinking so
Old Jul 11, 2007 | 04:48 PM
jwb's Avatar
jwb
Default "M" and "S" lights started blinking so
I got underneath the truck and filled the transmison pan with oil. Now the truck will only move in reverse. and trainy does not engage in the " D " position. I hope I didn't burn it out [&o]..........................Help!!!!!.
Old Jul 11, 2007 | 05:13 PM
Default RE: "M" and "S" lights started blinking so
What year, how many miles on it and how low was it?
Mike
Old Jul 11, 2007 | 07:38 PM
C's Avatar
C
3rd Gear
99 discvery 2 code p1590 need to know more to fix
Old Jul 12, 2007 | 11:04 AM
jwb's Avatar
jwb
The truck is 99 disco II. It has 120K miles, the oil was exteremely low so I put in 2 1/2 quarts and it took it all. I am going to try draining the panand refill it again. This time I will adda bottle of Lucas additive.
Old Jul 12, 2007 | 01:13 PM
okdiscoguy's Avatar
ORIGINAL: C
I take it this is not related to the topic, but all you need to do is clear the code. Just Rover trying to scare you. It is a rough road code, nothing to do to fix it..unless you call the DOT.
Old Jul 13, 2007 | 10:05 AM
jwb's Avatar
jwb
Anybody have any idea of what may be happening with the transmission? I also noticed that the " D" flashes when it's on drive.
Old Jul 13, 2007 | 10:15 AM
okdiscoguy's Avatar
I am not sure on this one. I know some had fill plugs, and no dipstick. I think you have to check the level cold with the engine running, but I am not sure. Mike has the same truck and should know.
Did it stop engaging before you messed with the fluid? May need to have it towed to a Rover shop to have the codes read..
Old Jul 13, 2007 | 11:16 AM
ORIGINAL: jwb
If you are still having problems, and I imagine you are, you might want to call me or have me call you and go thru a few things to check.
Mike
mikeljacobs@comcast.net
Old Jul 13, 2007 | 01:58 PM
jwb's Avatar
jwb
Hi, Mike I sent you my cell number via e-mail. If you rather that I contact you please send me your contact number at my E-mail addrress.
jbup@yahoo.com
angasreid
Dec 16, 2023 07:45 AM
RegT
May 21, 2010 10:22 PM
likenmori
May 30, 2008 10:01 PM
Millchil
Apr 9, 2008 08:54 PM
jbrandtpollock
Jun 26, 2007 08:20 AM
