"Service Engine" Light on
Old Apr 4, 2008 | 12:50 PM
Gama's Avatar
8th Gear
Default "Service Engine" Light on
Hi guys. Just now my 'SERVICE ENGINE' light came on, and it stays on. I was on a ramp to the HW... I drove for maybe 3 KM and got to work - Parked in the garage I turned her off, and then back on, but the light is still on. I did a quick check under the hood and there are no leaks - the temp is normal.
There is a flickering sound like ... like there was a leak through the engine head gasket... but I would see oil if that was the case... I think.
Any ideas before I take it to my mechanic?
Any help would be greatly appreciated.
Thanks in advance.
98 D1 134,000 KM
I just recently started using Premium Gas (2 weeks ago)
Have had the car for just over a month.
Old Apr 4, 2008 | 01:13 PM
humroot's Avatar
Default RE: "Service Engine" Light on
Take it to AutoZone or someplace like that and they will read the codes for you for free. Post the codes and we can tell you what's going on.
Old Apr 4, 2008 | 01:24 PM
Get the codes read and get back to us with the exact four digit numbers.
Old Apr 7, 2008 | 04:41 PM
Gama's Avatar
8th Gear
A friend of mine had a reader and it came back with no codes. After checking several times, I searched on the light itself, and it appears that there are 2 totally different ligths.
There is the SERVICE ENGINE(The one I got) and the CHECK ENGINE lights.
The first one appears to be a service check reminder - emissions maybe? - set to trigger at 135,000 KM (around 85k miles).
The CHECK ENGINE would've been a whole different ball game.
I think this info is correct, but if I'm mistaken, please let me know.
Thanks for the responses.
Old Apr 7, 2008 | 05:03 PM
Yes, you are right, the light that you have on is a service maintance light that comes on about every 80,000 miles that can be reset after the service is performed.
Old Apr 7, 2008 | 05:10 PM
There is a way to reset the light without having the service done, but you really should have the service done to keep everything running right and to keep the emissions in check.
Old Apr 8, 2008 | 11:26 AM
Gama's Avatar
8th Gear
Spike, I had the emissions test and revision done a month ago, so I guess it's ok to clear it.
How would I do it?
Old Apr 8, 2008 | 04:48 PM
http://www.discoweb.org/index.html
Look for the reseting service engine light link in the tech page.
Old Apr 9, 2008 | 04:24 PM
Gama's Avatar
8th Gear
Thanks a bunch mate.
Old Apr 9, 2008 | 04:27 PM
Did it work?
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97rover
Apr 13, 2005 02:19 AM
rushour000
Mar 31, 2005 05:16 PM
