[NAS 2003 S] Fog Light Retrofit Question
Old Jan 7, 2015 | 11:29 PM
Alex_M's Avatar
Default [NAS 2003 S] Fog Light Retrofit Question
Hey guys. I have a 2003 S Model Disco. For some time I have had a set of factory fog lights and bumper caps installed off of my '04 parts truck, they're hooked up and everything, but I can't seem to get them to work. I'm almost tempted to just rewire them, but I figured I would give it a stab here on the forum first. Do I need to install an extra relay? Where does the switch out of the '04 go in my '03? I only found one plug in the dash that it will actually plug into, but it didn't do anything. Thanks guys!
Old Jan 8, 2015 | 12:04 AM
jafir's Avatar
Yes on the relay, in the under hood fuse box I think. Fuses too if they aren't already there. You'll need both fog buttons from the parts truck. Then you might need to have the BCU reconfigured to know the dogs are install.
Old Jan 12, 2015 | 09:30 PM
ZB-30's Avatar
You also have to install a new rear fog light switch. On the S model the rear fog light switch is on the top left, but when you add the front fog lights that is where the switch for the front goes. The top switch is shaped a little different than the switches that go below it so you need to pull that rear switch from your parts truck as well.
Old Jan 12, 2015 | 09:50 PM
jafir's Avatar
I did say both buttons.
abran
Oct 1, 2013 09:09 PM
PKG Vitesse
Jan 25, 2013 09:27 AM
FMV
Jun 25, 2008 07:59 AM
stanigu
Jan 10, 2007 06:31 PM
Disco Alan
Jul 11, 2006 06:33 PM
