A\C Issues
Old Aug 5, 2008 | 08:25 PM
sayre05's Avatar
Default A\C Issues
I have a 96 Disco SE7 with Rear Air. My air was not working so I got a gauge set and 2 cans of freon. I filled it to 40psi and the temp of the air 0nly goes down to 80 degrees on high. Checked against my neigbors and he gets down to 66 degrees at the same 40 psi. What else can I check. This has a new rad put in yesterday and I cleaned everything out of there that would cause blocakage. Thanks for any help!
Old Aug 5, 2008 | 08:45 PM
Default RE: A\C Issues
Is the rear air not working or all of it? Are your electric fans coming on?
Old Aug 5, 2008 | 08:50 PM
sayre05's Avatar
The front and rear are blowing at about 80 degrees. Before I added freon it was blowing about 90 degrees front and back. Its cooler but definatly not right. The front fans do come on. Thanks
Old Aug 5, 2008 | 08:55 PM
Ok, if the electric fans are coming on then you need to look at the compressor or the evaporator. You might need to take it in to a shop. Did you try cleaning your condensor with the garden hose?
With the trk off take your hose and rise the radiator from under the hood out towards the front and then from the outside in. If it is dirty then air cannot flow past very well and then it wont work well.
Thats all I have, sorry I cant help more.
Old Aug 5, 2008 | 09:05 PM
sayre05's Avatar
Thanks Spike555, I just cleaned it out as best as I could when I put in a new radiator yesterday.
Old Aug 5, 2008 | 09:07 PM
Was it cold before you put in the new radiator?
Old Aug 5, 2008 | 10:10 PM
sayre05's Avatar
No it was not. I got this about three months ago. I have had to due head gasets, fan clutch, rad was completely shot. Complete tune up, almost completely new suspension, new CV joint on driver side, still need to do springs. And a million other little things. What would you start with compressor or condensor? I cant find a reasonable shop in the area, for what they want to just look at it I could almost replace the whole system. Thanks
Old Aug 6, 2008 | 10:27 AM
Phototone's Avatar
You don't need to find a Land Rover shop Any auto air conditioner shop can do all repair on your Discovery air conditioner. Automobile Air Conditioning is all fairly common parts, and the mechanical functions and how they work are identical regardless of whether you have a Buick or a Land Rover. It is possible that your system has air and moisture in it, and needs to be put on a vacuum pump for a few hours to draw down vacuum and remove internal moisture. Just a modest amount of internal moisture or air contamination can cause the symptoms you describe. Your radiator would have to be extremely dirty to affect performance THAT much. A common air conditioning service should cost $100 or less if no parts are needed.
Old Aug 6, 2008 | 11:07 AM
Do your self a favor, stop working on it and go back to the basics.
Suck the system down, see how much you get out and measure that against what should be in there. If the level is right, check for plugged orifice filter.
If this is Greek to you, get it into a shop and have it tested properly.
ceedee
19
Jun 21, 2006 09:44 PM
fidel309
Oct 9, 2005 03:41 AM
drpenaranda
Oct 3, 2005 10:08 PM
Bene
Jul 10, 2005 09:42 PM
richo888
May 12, 2005 11:50 PM
