‘04 charcoal canister question
Old Sep 8, 2022 | 03:00 PM
Tony Luna's Avatar
Default ‘04 charcoal canister question
Been getting a persistent P0441 code as of late. Truck runs great.
New purge valve at time of engine rebuild about 8K ago. New connector for purge valve soldered in. New vacuum lines. New genuine gas cap.
How should I check the charcoal canister for proper function? It is original with over 280K. No issues filling the tank (other than $6/gal) or fuel smell.
Thanks,
Old Sep 8, 2022 | 10:22 PM
04disco2va's Avatar
Mine was full of fuel and maybe water. Worth checking.
Old Sep 9, 2022 | 01:41 AM
Brandon318's Avatar
Same code. Got it pretty often on both my 2002 and 2004 and happens whenever it gets warmer than normal outside. Not sure if there's a correlation there. Same same replacements as you. Just decided to live with it until maybe someday stumbling upon the fix.
Old Sep 9, 2022 | 02:33 PM
WaltNYC's Avatar
My P38 acts the same way regarding weather. P0440 comes back in the summer. Not so much in the winter.
Old Sep 9, 2022 | 02:39 PM
hasullivan's Avatar
@Brandon318
That 04 is sensitive to pressure change. Code triggers when at altatude for a while, refuel at altitiude change, sometimes refuel at < half a tank(this may be related to the external temps). From what I can tell it always goes about 3 days after initial potential code is thrown. Seems like it wont let go of the code even if its not being triggered any more. I suspect its a loose fitting breather tube, but have not had any time, or energy in this heat to test.
I should get a barometer and take notes.
@Tony Luna
As 04disco2va said, take it out and see if there is any fluids in it and that its not blocked up.
Old Sep 9, 2022 | 05:57 PM
Tony Luna's Avatar
Thanks for all the replies.
It has been warm as of late.
I’ll take it out to see if it’s full.
Old Sep 10, 2022 | 01:59 AM
Discorama's Avatar
What purge valve did you install? Hyundai didn't work for me. I installed a Bosch and P0441 was gone. Obviously some of these Hyundai valves behave differently.
Old Sep 10, 2022 | 12:51 PM
Best4x4's Avatar
When you do the Hyundai Purge Control valve it MUST be the OEM Genuine Hyundai part. The units from BWD, Dorman, and other aftermarket = pure junk. I have yet to ever have a Genuine Hyundai Purge Control Valve fail or act up on any LR I have installed one on. All of my D2's are using them as well.
Old Sep 11, 2022 | 02:28 PM
Brandon318's Avatar
Originally Posted by hasullivan
@Brandon318
@Tony Luna
LMK what you find because the same thing happens on the 2002 as well. It doesn't affect anything, more just a periodic reminder that the ultra gauge beepy works haha
Discorama
Sep 28, 2022 11:43 PM
cvhyatt
May 5, 2021 12:27 PM
DisCody2
Sep 6, 2020 07:02 AM
Antmen
Jan 11, 2020 06:52 PM
toofaroffroad
Oct 24, 2014 07:28 PM
