'00 Sunroof leakage
'00 Sunroof leakage
Hi! I recently bought an '00 Discovery II. IT has rained a few times since then and has been just fine. Yesterday however, there was a monsoon. The sunroofs themselves don't actually seem to be leaking but there was water coming from around the buttons for the roof, it poured out of the mapholders above the sunvisors, and had constant drips from everyone of the air vents in the roof. Where do I start?
RE: '00 Sunroof leakage
Well open the sun roof and look for the 2 drain openings in the front corners of the sun roof, if they are plugged, usually a little air pressure will clean the out. If the hose has come loose, you'll need to drop the head liner a little to find the hose and reattach it.
