'00 Sunroof leakage
Old Sep 16, 2007 | 11:06 AM
beachpugx1's Avatar
7th Gear
Default '00 Sunroof leakage
Hi! I recently bought an '00 Discovery II. IT has rained a few times since then and has been just fine. Yesterday however, there was a monsoon. The sunroofs themselves don't actually seem to be leaking but there was water coming from around the buttons for the roof, it poured out of the mapholders above the sunvisors, and had constant drips from everyone of the air vents in the roof. Where do I start?
Old Sep 16, 2007 | 11:27 AM
Default RE: '00 Sunroof leakage
Sounds like either one of the two drian tubes is plugged or has pulled loose causing it to rain inside your truck. How mechanical are you?
Old Sep 16, 2007 | 11:31 AM
beachpugx1's Avatar
7th Gear
Not extremely mechanical here, but can usually figure things out with a little time.
Old Sep 16, 2007 | 12:38 PM
Well open the sun roof and look for the 2 drain openings in the front corners of the sun roof, if they are plugged, usually a little air pressure will clean the out. If the hose has come loose, you'll need to drop the head liner a little to find the hose and reattach it.
Old Sep 16, 2007 | 03:42 PM
johnnybob06's Avatar
Drop the headliner?!
How do you do this??.... and normal car's don't do this stuff!!.. ugh!..
but then again.. are Rover's ever considered normal?! hahaha
John-Robert
Old Feb 23, 2012 | 09:40 PM
slimtexas1's Avatar
Mine does the same thing. Going to try the plug thing tomorrow and see if that works.
jnwinca
Oct 7, 2019 10:45 PM
jdelp
Aug 16, 2007 03:00 PM
johnnybob06
Jul 18, 2007 12:16 PM
mummra
May 29, 2007 09:48 PM
JEFF
Apr 29, 2007 11:15 AM
