01 air suspension lift
Old Feb 14, 2008 | 02:58 PM
DiscoIIRoop's Avatar
Default 01 air suspension lift
I was talking to a local mechanic who is a licensed land rover mechanic (only one in Columbus Ga). He was saying that he could lift the rear end by about 3 inches with just hooking it up to his computer and reprograming the air ride. I was wondering how true this is and if it is safe. Also would there need to be any other work done to it if I had that done. I know this will only lift the rear so I would need to do something in the front. Also does anyone happen to know the stock backspacing on the stock 01 se7 wheels?thanks
Old Feb 14, 2008 | 03:25 PM
Default RE: 01 air suspension lift
Don't do it, his way of lifting it will over inflate the bags, make it ride like a dump truck and cause quick bag failures.
Go to, http://www.rovertym.com/, order Steve's 2" SLS lifting spacer and adjuster, when installed, you can set up the rear to run between 2" and 3"s with less air pressure and a better ride, then you just need to put coils in the front and your set.
Old Feb 3, 2012 | 04:32 PM
2001SE7's Avatar
Default Another question about air suspension.
Go to, Welcome to RTE Welding & Fabrication!, order Steve's 2" SLS lifting spacer and adjuster, when installed, you can set up the rear to run between 2" and 3"s with less air pressure and a better ride, then you just need to put coils in the front and your set.
I found an SE7 that is really super nice but the air suspension has been removed. I have another SE7 that is dead but the air suspension is still functional. Does anyone here know if I could use my original parts to restore the air suspension into the one that has been removed? They are both 2001 SE7 and are identical. Java Black/Adobe Beige.
Hi Mike.
Ps; if you lift the front end of a Disco II with air suspension will the rear automatically raise to level the vehicle?
Old Feb 3, 2012 | 05:15 PM
drowssap's Avatar
yes, you can swap it over mine was the same way when i got it. and no the rear will not self adjust you need to add spacers.
Old Feb 3, 2012 | 05:22 PM
2001SE7's Avatar
Thank you.
ljdiscovery
Feb 13, 2016 11:21 PM
Emperor_MA
Jun 15, 2011 11:21 AM
Jantiz
Mar 17, 2009 12:00 PM
xb70valkarye
Feb 10, 2008 09:19 AM
brianwi11iams
Feb 18, 2005 04:09 AM
