01 Disco I II running rough w/code
Old Jan 31, 2009 | 09:58 PM
PJRover's Avatar
Default RE: 01 Disco I II running rough w/code
Thanks, Umimoged.
I've gotten so frustrated since I'm $4k deep into this (plus another K for other) and it seems like a bizillion hours. Thought I was doing the right thingtrying to keep another rig from going to "parts".What your saying makes sense. I will pull the front cover tomorrow and update my post.
Old Feb 1, 2009 | 06:30 AM
unimoged's Avatar
You will fix it I am sure and at the end you will have a very nice setup. Timing is tricky sometimes, so I am sure you have a repair manual with instructions and a diagram that you are following. Also, if I recall, you mention an aftermarket cam, is this an adjustable cam that allows you to vary the position of the cam sprocket on the cam itself?
Old Feb 1, 2009 | 09:55 AM
Paul,
When did you have the rebuild done, was it by Rover, has it been within the 1 year warranty?
Old Feb 1, 2009 | 10:15 AM
PJRover's Avatar
Thank you for the encouragement. I'm using a full hard copy LR manual - didn't know about Rave when I picked it up. As to the cam, the sprocket was keyed so I believe there was no adjustment.
Old Feb 1, 2009 | 10:19 AM
PJRover's Avatar
Mike,
The heads were rebuilt by LR of Dallas (I'm sure they sub them out to a separate shop). They were done last summer and as mentioned I've only got about 500 miles on them.
Old Feb 1, 2009 | 10:29 AM
Well consider you should have a 1 year warranty to fall back onto if inn fact it is related to any of Rovers work.
Old Feb 3, 2009 | 03:35 PM
PJRover's Avatar
Default RE: 01 Disco I II running rough w/code - Update
Opened it up last night - crank and cam are lined up correctly. Spoke with cam provider who agrees that this sounds like a cam alignment issue but asked me to pull the rocker arms and pressure test the cylinders to ensure they hold pressure - reasonable request as I would have to go there to pull the cam anyway.
Will update after doing that - good thing this is third vehicle....
tbuckt007
Mar 18, 2021 07:43 PM
dillhole
Feb 20, 2020 02:30 PM
95IdahoRover
Feb 2, 2010 06:58 PM
nzoliver
May 8, 2008 03:36 PM
mattrickman
Mar 13, 2008 09:28 PM
