01 discos keeps dying
Old Dec 17, 2008 | 09:24 PM
Lewdmachine's Avatar
5th Gear
Default RE: 01 discos keeps dying
i almost forgot i, he plugged his scanner in it and a fault code p-1835 or somthing i wrote it down somewere but cant find it. it said loss of power
Old Dec 17, 2008 | 09:25 PM
It is not the cam sensor, it is the crank sensor.
http://www.roverparts.com/Parts/ERR7354G.cfm
Its your money, replace what you want.
http://www.roverparts.com/Parts/ERR6169G.cfm
I would replace the crank sensor.
Old Dec 18, 2008 | 07:07 PM
5th Gear
Thanks for all the help put a new one in and it runs just fine.
Old Dec 18, 2008 | 07:19 PM
Put in a new what?
Old Dec 19, 2008 | 11:09 PM
5th Gear
a new crank sensor. I think my head gasket is leaking coolant on it and shorted it out
Old Dec 20, 2008 | 10:08 AM
ORIGINAL: Spike555
Crank sensor is for spark and cam sensor is for injectors.
Replace your crank sensor and it will run just fine.
I have heard that AutoZone has them for $60.
Drivers side of engine, half way down at the bell housing.
Boy, did I turn that one around, sorry.
Old Dec 20, 2008 | 10:10 AM
ORIGINAL: Lewdmachine
That is one of the biggest causes of failin crank sensors, might want to try tightening you v/c gaslet bolts a little bit, that will often stop the leak.
coffeewithjohn
Feb 9, 2014 02:34 PM
brye19
Sep 19, 2009 12:35 PM
jkid
Jul 18, 2009 09:23 PM
sarahgibbons5
Jun 14, 2009 11:36 AM
mikemeyer0
Off Topic
Apr 28, 2005 02:57 AM
