01 Wont start but will crank.
01 160K on the clock.
Did plug wires/ plugs and a CPS 2 times.
Its been on the Netbook 2 times.
Its not locked out and i have connectivity between the BCU and the ECU.
I even tried a Newer working ECU and re booted via netbook.
I also do not have a ground to my coil packs and am not getting spark.
who's got ideas.
who's got ideas.
Pull one spark plug, reattach the plug wire and ground the plug to the block. Have a friend crank the engine to see if you've got spark. It's easier to see the spark in the dark. If you've got spark then it's probably a fuel delivery problem. Make sure you hold the plug with pliers that have heavy rubber insulation on the handles or else your elbow will end up in your shoulder!
I'd download the electrical manuals from this website and start continuity checking to be sure it isn't a broken wire.
I might even just start off by jumping the possibly broken wire just to see what happens. If the ground from the starter pack just goes straight to ground, I'd ground it on something under the hood.
I'd very carefully read the RAVE sections on the ignition system to understand how it works.
Wish I could say "do this, it'll fix it" but electrical problems are always a PITA.
retrac
09-12-2008 03:52 AM
