02 4.0 into an 03. Would you?
Old Oct 28, 2012 | 10:17 PM
5bravobravo's Avatar
Default 02 4.0 into an 03. Would you?
I've been scouring around looking at various discos.
One great option is to grab a wrecked but otherwise nice 02 and put its motor into my broken 03.
I like the idea of having all the spares and my 03 is nice. I can get the wreck for under 1500, I figure I would put hg set in the 4.0 and install it.
Any words to the wise?
I'm looking at some d1's and may ditch the 03
Old Oct 28, 2012 | 10:33 PM
ZGPhoto's Avatar
Have you thought about an LS1 swap?
Old Oct 28, 2012 | 11:35 PM
Of course, but seems it seems that swaps on these rigs are not very common or sorted out. Not looking for an engineering project at the moment. Just looking at cost effective solution to getting the 03 on the road.
If you have info regarding the swap I would be interested.
Old Oct 29, 2012 | 05:39 AM
drowssap's Avatar
4.0 & 4.6 are the same eccept for the rods and crank
Old Oct 29, 2012 | 09:27 AM
TATZOO's Avatar
I did the swap and happy I did it.....you can find 4.0's cheap and they bolt in, reprogram your computer and go....
Old Oct 29, 2012 | 09:43 AM
What is involved in reprogramming the ecu?
I am looking at getting the 4.0 from a wrecked donor vehicle so I will have all the controls as well, I could just swap the ecu?
How bad is the 4.6 tune with the 4.0 motor?
Thanks
Mike
Old Oct 29, 2012 | 05:12 PM
TATZOO's Avatar
Mike,
I had mine installed at a professional shop, so once the motor was installed (its all plug and play) the technician plugged in some bad @ss overgrown code scanner and reprogrammed the ECU so I have no idea what it entails but it worked perfectly.
Steve
calebbo
Oct 12, 2011 09:54 PM
rover11
May 26, 2011 11:21 AM
RovingRiesensCubed
Jan 12, 2008 01:11 PM
05LandRover
Off Topic
23
Jan 20, 2006 08:26 PM
Off Topic
Apr 28, 2005 04:20 AM
