03 - 04 MAF Part Id
Old Apr 1, 2018 | 09:00 PM
  #21
Best4x4's Avatar
No I don’t have the P/N off hand, but I know I’ve seen it on the AB website & ebay.
Old Apr 1, 2018 | 11:29 PM
  #22
Alex_M's Avatar
Your local auto parts store should have a bunch of o-rings in stock. You could take your air box lid in and match it.
Also Lowe's carries an assorted pack of large o-rings for like $5 or $10 that should have the right size or close enough.
Old Apr 2, 2018 | 01:10 AM
  #23
OverRover's Avatar
Originally Posted by mr. choodles
@Best4x4, thank you for the information! Do you know the part number for the rubber o-ring/gasket that goes into the 4.0L airbox lid? After ordering a set of wrong parts, I'd rather double check ;-)
Have at it
Old Jun 24, 2020 | 07:16 PM
  #24
Tony Luna's Avatar
Ok, so I followed this thread and ordered just the MAF insert for my ‘04 D2.
Seems like I mistakenly ordered the Delphi AF10156.
What I pulled out of my MAF housing is a Bosch F 00C 2G2 029.
Same connector and mounting flange, but the Delphi insert is a little different than the Bosch.
Are they interchangeable? Does anyone know for sure? Best 4X4?
Old Jun 24, 2020 | 08:10 PM
  #25
Best4x4's Avatar
I've installed a few aftermarket Delphi units on customer D2/P38's. They worked when I installed them.
Old Jun 25, 2020 | 10:04 AM
  #26
Tony Luna's Avatar
Granted, I did not install it. Don’t know if it’ll work - or not. Just saw that it was different and decided to clean the Bosch while I had it out and reinstalled. The Delphi insert had an additional wire/sensor.
Old Jun 25, 2020 | 10:07 AM
  #27
Tony Luna's Avatar
Same Delphi P/N? AF10156
Old Jun 25, 2020 | 10:41 AM
  #28
Best4x4's Avatar
Delphi P/N: AF10383
Old Jun 25, 2020 | 10:45 AM
  #29
Best4x4's Avatar
However the P/N you list also shows as compatible. I think one supersedes the other.
Old Jun 25, 2020 | 01:14 PM
  #30
Tony Luna's Avatar
Delphi P/N: AF10383
The one pictured looks more like the Bosch insert. Maybe I'll grow a set and give the Delphi AF10156 a try.
Shiftonthefly1
Mar 13, 2015 01:17 PM
DonRW2007
Jan 6, 2014 09:19 AM
bosshogt
Mar 31, 2010 02:54 PM
Different Drummer
Oct 1, 2006 07:03 PM
