03 4.6 any way to identify/prevent slipper liners?
Old Aug 30, 2011 | 11:33 AM
  #21
94svt50's Avatar
As far as the liners go, there are lot of people who have replaced about every moving part in the engine trying to fix the tick yet they are unable to stop it. The only constant is they reuse the same block.
Old Aug 30, 2011 | 08:48 PM
  #22
ruffram's Avatar
I am worried about it for sure. I definitely don't want to put it all back together with new bearings and seals and still have a noise. I plan to "pin" the liners I think since they don't appear to have slipped yet.
Old Aug 30, 2011 | 09:20 PM
  #23
RoverDoctor's Avatar
4th Gear
Default Liner Issue
If you have a dropped liner, your car with overheat within a few mins.
You dont hear a liner tapping, you hear your cam and bearings, lost oil pressure at one point very common. with a liner issue u cannot drive the vehicle very far. Ive seen a lot
Matt
Old Aug 30, 2011 | 09:37 PM
  #24
94svt50's Avatar
If there is no crack behind liner into water jacket then you can drive it forever.
Old Aug 30, 2011 | 10:14 PM
  #25
ruffram's Avatar
Im worried about a crack in the block somewhere too. Machine shop said they have no way to check an aluminum block for cracks. However, None of the pistons were steam cleaned, and there was no water in the oil, no milky mixture in the pan or any milky deposits anywhere in the heads or valley etc. However, when driving it you could hear the sloshing sound in the dash and when looking into the coolant reservoir it did put off bubbles at a fairly steady pace. I really expected a bad gasket or steam cleaned piston or a slipped liner and I found none of the above. Only a trashed crank and rod bearings. Everything else really doesn't look that bad. The sloshing and steady stream of bubbles really make me think the was a leak in the cooling system somewhere, but now I'm at a loss
Old Aug 30, 2011 | 10:31 PM
  #26
disc oh no's Avatar
Did you try bleeding the cooling system? Maybe it's just low and has air bubbles running around in there???
Old Aug 30, 2011 | 10:37 PM
  #27
disc oh no's Avatar
Matt
Rover Doctor, if you have your heads off, can you tell just by looking at the liners if they have dropped? Just curious, it sounds like you've got lots of experience with these engines. Thanks for your time!
Old Aug 31, 2011 | 04:11 PM
  #28
ruffram's Avatar
No I didn't. I was so anxious to get this thing apart to see what was going on inside it I didn't mess with it
Old Aug 31, 2011 | 04:19 PM
  #29
disc oh no's Avatar
Well, the best thing to do would be to pressure test the block at this point. You just have to seal off the four ends of the block faces and the water pump housing as far as I know, then put some pressure to it and see what you get. Check out the video on youtube from the singing camel rover shop. I think it's called "slipped sleeve syndrome" if you want to see what it will look like if you're losing pressure. Good Luck!
Old Aug 31, 2011 | 04:32 PM
  #30
ruffram's Avatar
I thought about that, but I read of other guys who pressuere tested blocks and they were fine, but then installed them in the car and ran them and still had block problems/leakage. Problem seems that if the block passes the test it doesn't really tell you anything. Only that it might be ok but no gaurantee
