03 DII transfercase reseal
Old Dec 29, 2009 | 12:23 AM
discoboy's Avatar
Default 03 DII transfercase reseal
Well the leak from my transfer case has gotten worse, saw 3 drips on my driveway after
parking there for 2 hours. My question is does anyone know what parts are needed to perform the reseal. Thanks
Old Dec 29, 2009 | 07:18 AM
hilltoppersx's Avatar
a wrench, an oil pan to catch old oil, a new seal, hand or electric pump for refilling, new oil to refill.
get the rave manual it specifies how to do it.
Old Dec 29, 2009 | 08:38 AM
Bryan H's Avatar
What is leaking? The cover or front seal? My front seal leaks and that can't be easily accessed. If it's the seal, a product called White Sheppard may help.
Old Dec 29, 2009 | 09:28 AM
Good point, what is leaking???
When done, consider throwing in some White Shepherd to stop and other leaks and use a 75W/140 gear oil from now on and there will be no more leaks.
Old Dec 30, 2009 | 11:46 PM
discoboy's Avatar
Hey guys, the leak appears from the front seal, I will probably start work next week. Reseal the transfer case, replace rear main seal that is already seeping. What are your thoughts of resealing the front pump on the trans? Its already out.
gundog
Sep 3, 2015 09:21 AM
damygoliath
Oct 2, 2013 09:18 AM
kpl1228
Dec 5, 2010 01:38 PM
jwood700
Nov 21, 2009 10:26 AM
ajh
Sep 17, 2006 02:36 AM
