'03 Disco 2 misfires on cyl 2, 3, 5, 8
Old Jul 1, 2016 | 09:30 PM
keenyoung's Avatar
Default '03 Disco 2 misfires on cyl 2, 3, 5, 8
I'm getting codes for misfires on cylinders 2, 3, 5, and 8, and P1300 random misfires. Since those cylinders are all on the same coil, I suspect that coil, or the wiring to the coil. Those cylinders are on both banks of the engine, so it would seem not to be vacuum leaks, O2 sensors, cats, or other causes.
Do these things usually fail on a single side, or both packs at the same time? Is my diagnosis sound? How do I test for it?
Thanks,
Keen
Old Jul 1, 2016 | 10:33 PM
disc oh no's Avatar
That does sound like a bad coil or wiring, like you said. Are there fuses for each coil? I don't know. I guess it wouldn't hurt to check. If not, you could try swapping them and see if the misfires follow. That's not a fun job though. There's not much room back there.
Does the truck run at all? Or are they intermittent misfires?
Old Jul 2, 2016 | 12:20 AM
keenyoung's Avatar
Thanks for the reply. As it turns out it was my own fault. I just finished up a head gasket job, and apparently I didn't get the right side wiring harness connector fully seated when I put the coils back in. Running fine now, except for an annoying ticking from the left bank. I guess I should have ponied up the money for new lifters when I had the thing apart.
Keen
Old Jul 2, 2016 | 01:32 AM
mln01's Avatar
That'll do it.
Old Jul 2, 2016 | 06:01 AM
Charlie_V's Avatar
Keen
Best possible outcome!
Old Jul 3, 2016 | 04:01 PM
disc oh no's Avatar
That's great that you found it and it didn't cost you anything, aside from a little stress! We all make mistakes like that from time to time. Especially on such a big job.
coors
Sep 9, 2011 02:15 PM
tbesselman
Nov 17, 2006 01:20 AM
rcm
Nov 5, 2006 10:27 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
