03 Disco HSE7 at my whits end with codes
Old Nov 12, 2025 | 07:01 PM
Johnyakimo1855's Avatar
Well, battery was bad. Infuriates me. Bought it right before i parked it. Did not even have 25 mins on it. Ordered a Group 31 battery. It will be in tomorrow, so I will keep yall posted on what happens next. Thanks Everyone
Old Nov 13, 2025 | 09:34 PM
Harvlr's Avatar
Even a brand new high quality battery, if let run quite low, will never be the same.
Old Nov 15, 2025 | 10:33 AM
Ok, so installed new battery (Type 31), Cleared all codes. Did what Extinct told me to do and touched cables together and lock/unlock three times. Cleared everything
Only thing left is the flashing green light up in far left corner. Any ideas how to clear that one?
Thank EVERYONE for the help!
Old Nov 15, 2025 | 11:21 AM
H20nSnow's Avatar
How exactly did you clear all codes? You are using the Nanocom, right? You have to dig into all of the different menu paths to get to the different functions and codes. Different menus control different functions. For instance you have to go into the Airbag menu to access the SRS codes and clear them. However, with the seats out you won't be able to clear that. When you pull the seats you have to disconnect the seat belt tensioners and that will cause a code and light the SRS light. You won't clear that one until you reinstall the seats. Make sure you are looking at everything in the Nanocom.
Old Nov 15, 2025 | 04:09 PM
Spoke too soon.
Just went out to start it up and everything is lit up again.
Oasisplayer311
Feb 26, 2016 05:05 AM
jamestfl
Aug 17, 2015 01:18 PM
csp
Jul 1, 2013 07:33 AM
tarpon66
Jul 24, 2011 10:21 AM
rholtporsche
Aug 27, 2009 09:12 AM
