need help with codes on 03 discovery
Old Jul 22, 2011 | 05:52 PM
tarpon66's Avatar
Default need help with codes on 03 discovery
please help.. 03 discovery codes
p0103
p0150
p0327
p0159
p0139
check engine light came on... bad o2 sensor
replaced all o2 sensors
new alternator
new coil packs,plugs and wires
took it on an 80 mile run after clearing the codes..shut off the engine .. engine light came back on solid and rescanned .. came back with the above codes..
Please help, Respectfully,Mike
tarpon66@netzero.net
Old Jul 22, 2011 | 05:59 PM
tarpon66's Avatar
Default Forgot to add changed knock sensors as well
Old Jul 22, 2011 | 08:18 PM
tarpon66's Avatar
Come on guys... please ..I need some input here... I see post that followed mine have responses.. yet 14 views and no responses as of yet...
Thank you all in advance
Old Jul 23, 2011 | 12:11 AM
csbd's Avatar
What were the codes the first time? The way I read it, either the connections are not good or the replacement sensors are faulty. I would check and clean the sensor connections, reset and see if any codes return.
Old Jul 23, 2011 | 03:59 AM
tarpon66's Avatar
Thanks for the response..
the codes the first time said that the two upstream 02 sensors were bad
so I replaced them all.. came back telling me the 2 upstreams were bad again..so I replaced them with 2 new ones again,, then it came back with one of the knock sensors were bad... so I replaced those... now it came back with the 5 codes as in the first post...
I'm at a loss at this point ????
thanks again ,,
Old Jul 23, 2011 | 08:08 AM
dgi 07's Avatar
thanks again ,,
Ok. If you have Rave and I am assuming you do? What do those codes translate to. Ifyou can tell me that, i'll help you out
Old Jul 23, 2011 | 08:41 AM
Sent you a PM reply.
Old Jul 23, 2011 | 08:48 AM
tarpon66's Avatar
correction on one of the codes I originally posted the first of 5 codes as reading p0103.. it should read as p0130
Old Jul 24, 2011 | 10:21 AM
tarpon66's Avatar
@ Disco Mike,
P0130 - 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0150-"oxygen sensor circuit slow response, upstream sensor bank B"
P0327- knock sensor on Bank #1 is generating a low output voltage
P0159 - Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
P0139 - Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
