03 disco overheating
Old Jun 26, 2018 | 08:16 PM
  #31
redwhitekat's Avatar
Sam please don't do what I did and spend money on a pump I thought the same as you and installed new pump i bet you it's not it
try another thermostat your problem is exactly what I had and I could not believe it was the thermostat but after buying a 3rd warm weather from Atlantic British it finally worked
Old Jun 26, 2018 | 08:41 PM
  #32
Saturnine's Avatar
Any chance you've changed the temp sensor? I had some annoying coolant temp problems with my truck and it turned out to be a bad (new) temp sensor. Truck would overheat in the parking lot without driving and after replacing everything in the cooling system and doing the inline t-stat mod, this $23 sensor from AB solved my problems.
Old Jun 26, 2018 | 08:46 PM
  #33
Until that bottom rad pipe is hot there is very little flow in the rad
if the bottom rad pipe was hot and it was still overheating then it's something else
Old Jun 26, 2018 | 08:55 PM
  #34
Best4x4's Avatar
Any excessive pressure in the cooling system = HG’s. You can normally smell a combustion/exhaust smell in the reservoir, but rent the tool, buy the fluid and be done with being sherlock holmes/dr watson stuff.
Old Jun 27, 2018 | 05:03 AM
  #35
shanechevelle's Avatar
How long have you let it run for?
Old Jun 27, 2018 | 05:26 AM
  #36
Did you read his post where he took out the stat and the lower hose was warm?
I am going to do a test on mine when I get home
Old Jun 27, 2018 | 06:11 AM
  #37
no sorry missed that one
Old Jun 27, 2018 | 07:06 AM
  #38
That's ok, I do it too and have to go back and reread.
I wish people would post where they live, at least the state. If anyone was close I'd drive to help...I've driven all over to help people.
Old Jun 27, 2018 | 07:49 AM
  #39
are you the new version of disco mike. ?
Lol he tried to help everyone mostly by phone
Old Jun 27, 2018 | 08:22 AM
  #40
No. Is there something wrong with wanting to help people? Ever have a situation where someone showed up and saved the day? Isnt that why we are here in the first place? This forum is only a medium to help each other, someone travelling is just another way at accomplishing the same thing.
I've talked with Mike a few times many years ago. Wealth of knowledge. Why isnt he here anymore?
The cooling system on these things...not everyone gets it. Things have to operate awhile until they fall into that groove. When I finished with my head job last month I let the truck idle well into 45 minutes...bled bled and rebled. Originally I noticed upward temps etc. But I knew once everything cycled a few times it would be ok. The lower hose being warm....is understandable at start up and well into 5-10 minutes. The radiators job is to cool the coolant...it wouldn't be much help if the coolant stays super hot into the motor. That's why we need to determine how long someone let's their truck run for, if the stat had time to run its course etc.
Just because you dont have any air at the bleeder DOES NOT MEAN, there is no air. I just bled more air out last week and noticed the temp drop. It's amazing how a little coolant can lower the temps.
I dont think the OP's issue is with the radiator, the stat, or the waterpump.
