'03 power steering pump on '01?
Old Mar 16, 2010 | 10:45 AM
hayabusarider's Avatar
Default '03 power steering pump on '01?
Does anyone know if a power steering pump from an 03 and up Disco II is the same and the one from an 01? I want to replace mine and found one cheap, just wanted to be sure it will work. Thanks
Old Mar 16, 2010 | 11:13 AM
okdiscoguy's Avatar
yes, they should be the same.
Old Mar 16, 2010 | 12:17 PM
They will work, how much is the one you found, new or used and how many miles on it?
Old Mar 16, 2010 | 01:34 PM
greenwade's Avatar
make sure you pull the fan off at the start of the job. It is a HUGE time saver. I say this because i just learned the hard way. Remember to use blue lock tight on the threads of the pullies.
Old Mar 17, 2010 | 02:21 PM
I can get the pump off an 03 with 65k miles for 60 bucks locally. Mine has a bad whine and I thought for that price it would be worth a shot to fix it.
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
