03 Steering problems!!!
Old Oct 24, 2011 | 03:30 PM
DiscoGrlNC's Avatar
Default 03 Steering problems!!!
Posted this under Dsico I - OOOps!
2003 LR Disco SE7 - replaced steering pump. 2 different gearboxes installed. Repl 1st steering pump and gearbox as box was pouring PSF and ruined pump. New Pump and reman gearbox. Now, steering loose in straight position and intermittently while making right turns, the steering wheel will "stick" and "pop" into turning when you force the wheel past the sticking point. Was told gear box bad, but be missing a tooth in the gear itself, so replaced the box today with another. Doing the same thing now, only a little further into the right hand rotation than before. HELP!!!
Old Oct 24, 2011 | 05:07 PM
jafir's Avatar
Mine did that when I had a bad engine mount. It broke and was leaning against the steering shaft. You might check for anything interfering along the way from the steering wheel to the tires.
Old Oct 25, 2011 | 06:25 AM
drowssap's Avatar
check the flex joints on the steering shaft also
Old Oct 25, 2011 | 09:32 AM
What brand of pump and gear box are you using?
Is the system completely bled? You may need to tighten the gear box adjuster to correct the sloppiness.
Old Oct 27, 2011 | 08:28 AM
DiscoGrlNC's Avatar
Disconnected everything from the box and hand pushed the steering lever and it still hung up, couldn't be pushed thru rotation. Can't be the rods . . . hard to believe I got 2 bad boxes in a row. I replaced the original one because it was pouring PSF and ruined the pump. Second box was off of a Disco with 50K miles and this new one was supposedly reman from 03 Disco with 70K miles. Crazy and kinda hard to believe that both boxes would be doing the same type thing. This one is def tighter, but still has that catch come back from right hand turn rotation. ???? The catch is tighter when accelerating out of a turn and only slight when applying brake or slowing out of turn.
Old Oct 27, 2011 | 08:51 AM
ruffram's Avatar
Steering stabilizer bent or damaged? Had a grand Cherokee that had weird steering and po had hit something and bent the tube so as turning there was alot of binding and popping
Old Oct 27, 2011 | 08:52 AM
DiscoGrlNC's Avatar
I will have to ck that out. thx ruffram. i'll let you know
Old Oct 27, 2011 | 09:05 AM
You can drive without the stabilizer, it is there for off roading to keep a real hole from breaking your wrist.
Old Oct 27, 2011 | 09:14 AM
DiscoGrlNC's Avatar
So what do you think Savannah? What else should I be looking for?
Old Oct 27, 2011 | 09:23 AM
jafir's Avatar
have you looked at the steering shaft, where it comes down from the steering wheel to the box? There are parts that could wear out.
