04 D2 Fan Clutch and Blades. Options?
Old Jan 7, 2015 | 04:44 AM
golgafrinch's Avatar
Default 04 D2 Fan Clutch and Blades. Options?
I ended up taking my water pump and fan off together because I couldn't get that fan clutch nut to break loose. I'm looking to replace the fan but the one that came off my '04 has the clutch and fan as one piece. I've read that I can use one of the older fan/clutch combos. Is this true? And if so, will it mate up to the existing water pump/pulley?
Old Jan 7, 2015 | 05:31 AM
abran's Avatar
Yes, perfect fit.
Old Jan 7, 2015 | 10:15 AM
jafir's Avatar
The dollar is pretty strong right now, or the pound is weak, either way we are getting the best conversion rate in quite a while.
FAN AND DRIVE ASSEMBLY COMPLETE(BORG WARNER) PGG000080 Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
Old Jan 7, 2015 | 10:32 AM
5kcstq's Avatar
Sure you can use the earlier DII two piece fan/clutch setup. I'm running that on my 03. I used a new Hayden HD fan clutch and ebay'd the early fan. I think I paid $65 for the clutch and about $20 for the fan.
Hope that helps.
jafir
Feb 10, 2017 11:08 AM
DiscoRover007
Nov 19, 2012 11:20 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
