04 DII Water pump/fan clutch
Old Apr 19, 2014 | 06:24 PM
upnatm's Avatar
Default 04 DII Water pump/fan clutch
Got some knocking and wobble going on from the pump shaft. I've decided from scouring the forums, that I'll be replacing the pump with the HD pump with bronze impellor from bputah.com, and that I'll buy it a new "dance partner" fan clutch at the same time.
I'm a little confused as to whether or not I can use one of the recommended Chevy clutches on my 04. If so, can someone please tell me which one to order, and whether it will need mods to fit? Thanks much!
Old Apr 20, 2014 | 10:35 AM
SuperSport's Avatar
Originally Posted by upnatm
...I'll buy it a new "dance partner" fan clutch at the same time.
Somebody has been reading Savannah Buzz's threads...
Old Apr 21, 2014 | 07:05 AM
Paul Grant's Avatar
The fan/clutch assembly on '03/'04 models does not separate the way it does on earlier models. If you want to experiment with alternate clutches you're going to have to pick up an earlier DII fan.
jafir
Feb 10, 2017 11:08 AM
mmb
Dec 1, 2014 11:11 PM
dusty1
Aug 25, 2013 07:02 PM
rlrigsby
Mar 22, 2010 03:20 PM
rover1978
Sep 26, 2009 09:05 PM
