04 dii xyz / m+s / p0705
Old Jun 2, 2015 | 06:01 PM
Raider1974's Avatar
4th Gear
Appears to me that the inner side of the switch is a 360 degree little sprocket. Almost like an 8 mm ratcheting box wrench sprocket. It slides on right until I get to the flats of the selector shaft and stops stone cold.
Old Jun 2, 2015 | 06:05 PM
Raider1974's Avatar
4th Gear
Which side rests on the transmission ? The black or metal side ?
Old Jun 2, 2015 | 08:36 PM
mln01's Avatar
Your XYZ switch hub should look like the one in the picture I've attached. You can see the flat section on the bottom of the hub as it appears in the picture. That needs to be line up with the lower flat on the selector shaft. It should slide on easily if it's lined up correctly.
Attached Thumbnails 04 dii xyz / m+s / p0705-xyz-hub.jpg
Old Jun 3, 2015 | 08:01 PM
mln01's Avatar
Raider1974, can you share any update with us please?
medic1567
Feb 14, 2014 02:23 PM
saidrover
Jan 30, 2013 07:34 PM
saidrover
Jan 24, 2013 12:03 AM
USNavy041300
Freelander
Jul 29, 2008 06:36 AM
Dan87GT
Jul 22, 2008 08:19 PM
