Help!...Key Stuck and Transmission Code P0705
Old Jul 20, 2008 | 04:09 PM
Dan87GT's Avatar
Default Help!...Key Stuck and Transmission Code P0705
Hello...I performed a tranny service today on my '03 Disco, 72k...Filter and Fluid..I added 1/2 bottle to Lucas transmission conditioner, and 4 bottles of Dex III...after filling I put it in Reverse twice and then park to check the fluid..then my "M" and "S" lights started to blink and I can't get the key out. Ireset the codes butthey come right back on...please help!...
Old Jul 20, 2008 | 05:02 PM
2000 Disco 2 SD7's Avatar
Default RE: Help!...Key Stuck and Transmission Code P0705
Did you try pressing your unlock button your key? Also move the steering wheel while trying to remove key.
You need to run it through ALL the gears. Hold each one for 10 seconds. "R" count 10, "N" count 10,"D"-"3"-"2"-"1", and then back, counting to 10 on theway back too. Then check the fluid level and make sure that it is full.
Old Jul 21, 2008 | 06:07 AM
Dan87GT's Avatar
thanks...I am confused of the right time to check the fluid level..with a cold tranny, go thru each gear for ten seconds and then check the fluid with it running?...When I originally pulled the fill plug to drain the fluid at least a quart came out, the tranny was cold..
Old Jul 21, 2008 | 09:21 AM
I usually service my tranny when it is cold, drain and fill, start the engine, switch from drive to reverse 2 time, put it back into park and with the engine running top off the tranny.
Sounds like you were checking the level with the engine off. You should use a total of 6 quarts when doing this.
Old Jul 21, 2008 | 04:49 PM
Yes start with a cold trans, go through the gears like I said, this will bring the trans up to temp, then check with the trans in park and the engine running.
Old Jul 21, 2008 | 08:34 PM
Dan87GT's Avatar
Thanks fellas...worked like a charm...I got another quart in the pan...codes gone..thank you!!
Old Jul 21, 2008 | 08:55 PM
Glad all is well, and thank you for posting that it worked. Not enough people post when their problem is resolved.
Old Jul 22, 2008 | 06:38 PM
Dan87GT's Avatar
The sage continues...I come home today to find a 3ft by 3ft transmission fluid spot in my driveway....I used a new rubber seal and cleaned the pan the tranny before I reinstalled it..does any one use rtv on this seal?....thanks..
Old Jul 22, 2008 | 08:19 PM
A little spill will look bigger than it really is. Double check your work, if you need to re-check the fluid level.
Disco2 MTL
Dec 15, 2014 01:18 PM
ImQuattro
May 1, 2014 08:36 PM
medic1567
Feb 14, 2014 02:23 PM
saidrover
Jan 30, 2013 07:34 PM
plastique999
Jan 22, 2008 01:34 AM
