04' disco knock at idle
Old Jun 6, 2013 | 04:33 AM
Concours14's Avatar
5th Gear
Default 04' disco knock at idle
I just looked at an 04' Disco the motor was replaced approximately 3500 miles ago with an Alantic British motor. After the test drive me and the owner hear a knocking noise comming from the motor. The noise is the loudest when by the front drivers side tire. The noise will go away at approximately 1500 rpm and return at idle. It does not change with engine speed. The vehicle has 102300 miles on it. With only 3500 miles on the motor could it be a sleeve or possibly the cat coming apart? I am not sure where the cat is located on the disco, any ideas?
Old Jun 6, 2013 | 07:42 AM
drowssap's Avatar
keep looking, tell the owner to call you if he finds the problem, there are to many out there.
Old Jun 6, 2013 | 07:43 AM
Leave it along, you would just be buying yourself a lot of grief.
Old Jun 6, 2013 | 07:53 AM
CATs are left and right, sorta even with front driveshaft. If you want to look at it, a pre-purchase inspection by a mechanic would be a good idea.
As stated above, most would avoid this truck. At 3500 miles, what is his recourse with installing shop and AB?
Old Jun 6, 2013 | 08:10 AM
jafir's Avatar
That doesn't sound like an engine problem.
Old Jun 6, 2013 | 10:55 AM
Dan7's Avatar
A sleeve would change with engine speed, so would exhaust leaks or a bad lifter. Just set the idle stop screw to 1500 rpm
Old Jun 6, 2013 | 12:19 PM
Concours14's Avatar
5th Gear
The gentleman is going to take to the mechanic (a highly respected independent tech) for an inspection as it does have a warranty. I told the seller to let me know but as of now as you all have suggested it is of my list off vehicles. So my search continues which is a pain because there are no Disco's near me all are 11/2 to 2 hrs away.
Old Jun 6, 2013 | 12:38 PM
drowssap's Avatar
you never know he could come back and say it was something minor rattling, but might as well keep looking
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
