'04 Disco passenger window doesn't work
Old Oct 10, 2009 | 10:46 PM
Rustic's Avatar
4wd High
Default '04 Disco passenger window doesn't work
yesterday my passenger door window went down half way and refuses to move up or down anymore. Every time I press the window switch, I hear what I think is a relay making a "clicking" sound that it seems to be coming either from the door panel or underneath the glove box.
Has this happended to anyone? What do you guys think is broken or could be the problem?
Any advice is welcome.
thank you very much.
Old Oct 11, 2009 | 12:03 AM
sloppyjoe's Avatar
its either a bad window motor or more likely a bad window regulator.
dont worry it has or will happen to all of us. mine went 2 weeks into ownership.
good news is that in wither case you are spending a couple hundred bucks and you can replace a bad motor or regulator in a couple hours (working slow).
remove door panel. remove plastic moisture barrier. you will see the window motor and regulator assembly in the door. unbolt it and reverse the process.
Old Oct 13, 2009 | 10:07 AM
Troonus's Avatar
3rd Gear
Default Not unusual
Sloppy is right. I had the same problem with my 98 Disco LE within a year. I am not at all mechanically savvy and I was able to change mine out myself. I found a new regulator online for about $100 and changed it out in a hour or two. If you hear the clicking then the motor is most likely fine. Just pay attention to how you took it apart. My regulator was wadded up like a pretzel. Good Luck!
Old Oct 13, 2009 | 11:02 AM
sloppyjoe's Avatar
3 words all people must fear,,,
SLOPPY IS RIGHT,,,
frightens even me.
michaelfisk
Apr 28, 2018 04:22 PM
LRchick
Nov 9, 2012 04:59 PM
chig
Jul 21, 2008 02:33 PM
lionel
Oct 15, 2007 10:53 AM
NC1999HSE
Apr 14, 2007 12:39 PM
