04 Disco rear main seal leak
Old Jan 29, 2014 | 10:14 AM
NCguy's Avatar
Default 04 Disco rear main seal leak
Mike, you mentioned using a product to fix this issue, has anyone used any of these products and have they worked. Should I drop the transmission and replace the rear main seal or try this product?
Old Jan 29, 2014 | 10:34 AM
Dan7's Avatar
DIY cost...$7. I'd replace the seal.
Old Jan 29, 2014 | 10:35 AM
dusty1's Avatar
Okay, you hooked me. Gotta ask.
What is the product?
Old Jan 29, 2014 | 01:52 PM
Dan7's Avatar
A RMS is approx $7 at your local parts store...+ 6 hrs in labor Conversly, whatever additive you use may not fix the leak, if it does will only be temporary and may have unintended side effects on other components. On a $2K beater, go for it, but not a nice 04.
Old Jan 29, 2014 | 04:08 PM
NCguy's Avatar
ok ty for the feedback, I will replace the rear main seal. it also seems as my flywheel it slightly warped or the rivets have come loose or broken, it is taping on the crank shaft sensor and sounds like an tick or exhaust leak, weird but Bill at RTE found it out yesterday when I was there.
TOM R
May 13, 2014 07:56 AM
outdoor7or24
May 21, 2012 08:34 AM
discoboy
Sep 15, 2011 12:00 AM
Classklown90
Aug 22, 2010 04:26 PM
Belaou
Sep 11, 2007 07:43 AM
