04 slipped liner?
Old Oct 10, 2014 | 08:11 AM
  #51
RicketyTick's Avatar
yea only coolant passages adjacent to cylinders are the end cylinders. so if you find coolant in the middle cylinders it's a crack.
anyway, since you now know you have a loose sleeve, and you know you are loosing coolant somewhere, and you are getting misfires on the center cylinders, and you think the center plug or plugs were steam cleaned, you probably have a crack.
BUT you need to know for sure.
So..pressure test to find the leak, look in the cylinders for steam cleaning or coolant.
Old Oct 13, 2014 | 03:18 PM
  #52
RoverMasterTech's Avatar
Do the thermostat bypass, and dump 2 bottles of blue devil seal and go in there. Otherwise replace the engine. Only 2 ways to solve your problem.
Old Jan 9, 2016 | 03:04 PM
  #53
The_OGCJR's Avatar
Whatever came from your situation Sarge?
I've got the knock on the driver side of the engine, down low on the block, only when engine is cold and at idle rpms. I think I may have the slipped liner or cracked manifold. Just curious what you ended up finding.
expedio2005
Mar 15, 2015 10:45 PM
utah95
Feb 14, 2014 08:47 AM
TurboLS1Driver
Jun 19, 2012 09:04 PM
CurlyE
Mar 10, 2011 09:10 PM
