04 Transfer Case Swap
Old Jul 11, 2018 | 09:58 AM
zuke's Avatar
Default 04 Transfer Case Swap
I intend to swap out from an 04 to an 03. I was reading a recent thread about wiring issues in doing this. I did not know that this was a problem.
I have a parts truck so I can scab any parts or wiring harness that I need. Is this a straight forward deal or do I need to expect wiring issues?
Old Jul 11, 2018 | 11:50 AM
Jeff Blake's Avatar
Why would you go from CDL to no-CDL?
You're going to need to blank out the interlock solenoid on the top of the 03 case, or wire it in parallel with the solenoid on the shifter. Former preferred
As far as wiring goes... the only other thing I can think of is the temp sensor on the driver side of the case. Some cases have it, some don't
For the CDL switches you can just leave them unplugged
Old Jul 11, 2018 | 12:06 PM
zuke's Avatar
I think you misunderstood me. I have an 04 parts truck with a CDL. I intend to put that into an 03.
Old Jul 11, 2018 | 12:46 PM
Jeff Blake's Avatar
Ah, I did. The only thing to check for really is the two black lucar connectors for the diff lock. Apparently some trucks don't have it. If it doesn't, then swap in the transmission harness from the 04 as well.
edit: I would swap in the 04 harness anyway as the 04 box uses different connectors (and two of them) for the diff lock. If you keep the lucar connectors then you need to splice the switches together and/or buy an adapter
Old Jul 11, 2018 | 01:09 PM
Best4x4's Avatar
03 interlock solenoid should be mounted externally. If it isn’t it’s probay a late 02 TC. Yes swap the harness if you and it should be PNP.
CollieRover
Nov 18, 2015 06:29 PM
clint70
Apr 9, 2015 05:47 AM
halbertse
Apr 2, 2015 08:36 PM
ralphobell
Jun 10, 2014 10:08 AM
SolbergFanBoi
Apr 9, 2012 09:07 PM
