Hissing after truck turned off
Old Feb 20, 2012 | 10:43 AM
sdeleve's Avatar
4th Gear
Default Hissing after truck turned off
Hi Forum!
I heard a slight hissing sound last night after I turned my truck off and got out, then heard it again this Morning after a short drive. It sounded like it was coming from rear passenger side of the DiscoII. It only last a few seconds then stops? At first I thought it was the tire, but the pressure is fine. The sounds eventually fades away.....appears to be driving fine, no 3 amigos, or any other check lights.... any ideas?
2003 - 63K
Brakes and tires less than 2 years
600 miles per month - short distances
Thanks all!
Old Feb 20, 2012 | 10:48 AM
discotheque's Avatar
self leveling system leak?
Old Feb 20, 2012 | 11:00 AM
And instead of leak, it may be the vehicle adjusting - even though key is off, it will adjust to passengers leaving. From RAVE:
The door open signal powers the ECU for up to 30 minutes to allow the vehicle to re-level
when a load is removed or passengers leave the vehicle.
Old Feb 20, 2012 | 12:00 PM
sdeleve's Avatar
4th Gear
Thanks. I wondered about the level adjustment. Just that I've had my Disco for 8 years and never heard the hissing before. Nothing heavy in the truck and I weigh about 100 lbs soaking wet. Is there a way to determine if there's a leak and if so, is it critical to address??
Old Feb 20, 2012 | 12:06 PM
A leak can be located by soaking areas with a spray of soapy water and watching for bubbles.... But usually problem leaks leave the truck hunkered down after being parked overnight.
Old Feb 21, 2012 | 10:43 AM
sdeleve's Avatar
4th Gear
Thanks all -
It doesn't appear to be hunkered down so maybe I've developed super-sonic hearing.
She's going in next week for her 60K service and I'm cringing at the thought of what type of repairs she might need. I hear that the magic # is 60K for Disco starting to need major repairs!
In any event, thanks for the peace of mind.
zeblitz
Aug 24, 2014 08:33 AM
kcferna
Jul 7, 2009 08:33 AM
snowdude
Mar 19, 2009 06:51 PM
meltdowndave
Apr 21, 2008 07:39 PM
40ranger
Mar 19, 2008 05:11 PM
