11-14 MPG, is something wrong?
Old Nov 22, 2010 | 01:11 PM
  #21
JerrodSteph's Avatar
11 mpg here stop and go driving
Old Nov 22, 2010 | 01:39 PM
  #22
RegT's Avatar
14 mpgs i drive a mix of highway and local.
Old Nov 22, 2010 | 02:34 PM
  #23
Jeff5123's Avatar
Why the paper filter? how does this help?
Old Nov 22, 2010 | 03:11 PM
  #24
It doesnt, but using a "oiled" ait filter like a K&N air filter lets in more dirt as well as the oil from the filter is you over oil it and then it kills your MAF sensor.
Old Nov 22, 2010 | 03:36 PM
  #25
Jeff5123's Avatar
Thanks Spike.
Old Nov 25, 2010 | 06:43 PM
  #26
jycsalas's Avatar
The owners manual also suggests to put the tranny in N at stop lights to conserve fuel. I do it sometimes but forget to put it back in D and I just rev up and don't go anywhere. Silly me.
Old Nov 26, 2010 | 09:40 AM
  #27
hacksaw55's Avatar
4th Gear
The manual is wrong your vehical rev's higher in neutral
Old Nov 26, 2010 | 10:22 AM
  #28
jycsalas's Avatar
before you begin to correct certain members, do your research and take into consideration that some rovers are in better shape than others and do not idle higher in Neutral, check your IAC Valve...
File Type: pdf
Old Nov 26, 2010 | 04:33 PM
  #29
Shifting into neutral will remove the load from the engine, so even IF your engine did idle higher there would be no load on it, no load means less fuel used.
erietim
Sep 2, 2014 08:29 AM
raom16
May 7, 2012 04:31 AM
Chris-bob
Apr 30, 2012 02:17 PM
novavon
Jun 28, 2010 12:31 PM
IDAHODISCO
Mar 2, 2008 01:41 AM
