Which 180 thermostat to get.
Old Sep 23, 2020 | 11:37 AM
  #21
Oshawa_D2's Avatar
I hope the lucky 8 prop shaft is not crap. I just ordered it 😂.
in any case I contacted that email you guys gave me but it bounced back I wanted to order the OEM thermostat
Old Sep 23, 2020 | 11:55 AM
  #22
Dave03S's Avatar
I have the L8 propshaft, It's been fine for a few years now.
Does your device have a phone? L8 has one... You can call them on it if you have that technology. That way you won't have to wait for a reply.
Old Sep 23, 2020 | 08:01 PM
  #23
Oshawa_D2's Avatar
no but I have a rotary dial phone that still works 😂😭😭😂
Old Sep 23, 2020 | 08:19 PM
  #24
Oshawa_D2's Avatar
I went on the lucky 8 website and they no longer carry the OEM model
they have one replacement by Motorad and then there is a black one
The only place I found that has the gray unit you mentioned is the place below please have a look and let me know if that’s the part
https://rimmerbros.com/Item--i-PEL500110
Old Sep 23, 2020 | 11:11 PM
  #25
Richard Gallant's Avatar
@Oshawa_D2 Yup the grey has a softer spring, still a LR part. I ran one for a couple of years my temps were more consistent than with black I am currently running. With the grey I ran 188 on the move 197 - 201 hot idle at lights, 183 down long hills. My black has a larger range 183 -194 in general rarely breaks 195 at idle on pavement. Hard off roading I can get up to 201, long steep hills in low range, long down hills I hit 177 regularly. I am switching to an inline when I down my winter work or next spring depends on how much bad weather we get.
Old Sep 26, 2020 | 04:34 PM
  #26
Wheelspin's Avatar
I’m curious as I’m going to replace mine as well, what difference is a hard or soft spring ?
a friends got a disco 2 and fitted a 4.6 engine, he put in a Freelander thermostat
Old Sep 27, 2020 | 11:43 AM
  #27
redwhitekat's Avatar
I have also had good luck with Atlantic British soft spring warm weather thermostat
Old Sep 27, 2020 | 04:30 PM
  #28
rhyslegge's Avatar
If you cant find the genuine TD5 gray stat (lots of reputable eBay sellers carry this), then the inline thermostat mod is honestly your best bet, in my opinion.
Rhys L.
Old Oct 12, 2020 | 05:21 PM
  #29
Oshawa_D2's Avatar
Can some one confirm this is the correct oem 180 tstat?
https://www.britishpartsofutah.com/D...pel500110g.htm
Old Oct 12, 2020 | 06:16 PM
  #30
Extinct's Avatar
Rhys L.
You have that backwards
