1994 Disco Stalling out at lights and on road
Old Dec 10, 2007 | 07:37 PM
Rover5150's Avatar
Default 1994 Disco Stalling out at lights and on road
1994 Discovery with 158000 on the Odometer.
Have changed Air Filter, Water Pump, Thermostat,
Cleaned PVC, Stepper Motor, TPS, and MAF
Truck would idle rough when warm now
it stalls at red lights and has even cut off on the highway a few times.
Only codes were 45 (O2 sensor right bank)
and Code 19 ..........I also got a check engine light yesterday.
I was able to reset the codes and the lights and it ran better
but it is still stalling when warmed up
HELP!
Also noticed the coolant temp was bouncy yesterday and it started to overheat a little.
IS IT POSESSED?
Old Dec 10, 2007 | 07:55 PM
jkid's Avatar
Default RE: 1994 Disco Stalling out at lights and on road
Did it start overheating in the same time period that you changed your water pump and thermostat?
bmonkey4201
Jul 8, 2010 08:00 PM
bmonkey4201
Jul 6, 2010 12:26 PM
Rover5150
Dec 17, 2007 02:18 PM
Rover5150
Nov 28, 2007 09:57 AM
Rover5150
Nov 26, 2007 06:09 PM
