1995 Discovery Fuel Pump Wiring Harness
Old Mar 17, 2011 | 04:53 AM
james taylor's Avatar
6th Gear
Default 1995 Discovery Fuel Pump Wiring Harness
I took my '95 discovery to an electrical diagnosis shop because someting was killing the battery at night. They determined it was something between the fuel pump relay and the pump, but both are good. i can see wire these wires connect to the pump, but cannot see where they go from there. Does any know where i can find these wires and where exactly is the relay located? you can even text me. James 312-404-2842
Old Mar 17, 2011 | 08:06 AM
Bundu's Avatar
Banned
Download the service manual http://www.landroverresource.com/
Old Mar 17, 2011 | 08:59 PM
Rearden Steel's Avatar
James - post over in the D1 forum.
I believe their is also an inertia switch between the relay and the fuel pump.
Where are you located?
I don't recommend posting your cell number on an open forum.
Do you have Disco at home?
Do you have a battery charger?
Old Mar 18, 2011 | 04:53 AM
6th Gear
yes the vehicle is at home. where is this switch? what does it do? do you know whether the wires from the fuel pump run inside or underneath the vehicle. and, no, i don't own a battery charger. i just pull the full pump plug for now.
Old Mar 18, 2011 | 05:01 AM
6th Gear
wouldn't the inertia switch prevent the vehicle from running at all? mine sometimes lopes in idle, or cuts off ( sometimes), the fuel gauge reads no fuel ( sometimes)
Old Mar 18, 2011 | 07:13 PM
Generally yes..........it is meant to cut the power to the fuel pump in the event of an accident.
Old Mar 18, 2011 | 07:20 PM
Its on the firewall to the right of the windshield fluid tank.
Does this work? The fuel pump and sending unit should not be receiving any power with the key off.
theswede
Oct 29, 2015 01:05 AM
roving patrol
Mar 1, 2011 05:27 PM
kenk
Jun 25, 2010 11:54 PM
fulish
Dec 5, 2007 08:48 AM
