1996 disco cranks but won't start
Old Sep 7, 2008 | 10:44 AM
J dog's Avatar
7th Gear
Default 1996 disco cranks but won't start
good morning.
thanks to all who helped with yesterdays hazard light flashing issue. we pulled the hazard fuse in the underhood fuse panel and started the engine. lights stopped.
now it will crank but wont start. any ideas?
we were in some deep puddles last night. are there any extra sensative to water things i should be checking? pulled the batt ground and let it sit for couple hours. replaced the fuses in the under hood fuse box.
please help.
thanks
Old Sep 7, 2008 | 11:15 AM
Default RE: 1996 disco cranks but won't start
So everything else is good now? The hazards and all? You had it running but then this moring it just will not start?
Old Sep 8, 2008 | 07:46 AM
Landzu's Avatar
If you have not used dielectric grease on all thc connections you have a water problem.
The ECU is next to the washer jug and has a drain hole in the bottom corner.
dmatranga
Feb 5, 2013 12:27 AM
whitehat
Oct 29, 2012 02:13 PM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
VA Rover
Jan 9, 2010 06:56 AM
