1996 discovery only starts when back door open
Old Aug 19, 2007 | 10:43 PM
rravenn13's Avatar
Default 1996 discovery only starts when back door open
I know this sounds very strange but it is true my disco will not start unless I open the rear door. Please help! I am suspecting some strange electrical issue but I am stumped.
Thanks
Old Aug 20, 2007 | 07:44 AM
Landzu's Avatar
Default RE: 1996 discovery only starts when back door open
How well do you know wiring?
What changes when you open the door ? (the rear pin switch)
is no longer depressed and the light is on.
Short on switch?
Will it stay running after you shut the door?
If it does then it maybe the starter, and not the fuel pump.
I looked in my book last night to see if I could find ground points
it did not show them.
This maybe something you will need to get done if you don't have
a meter or test light.
Old Aug 20, 2007 | 07:53 AM
rravenn13's Avatar
Yes it does stay running after I shut the door
Old Aug 20, 2007 | 08:35 AM
Landzu's Avatar
ORIGINAL: rravenn13
Ok then you now have your starting point.
brandon4589
Feb 4, 2013 08:35 PM
1998DiscoverySE
Feb 8, 2012 02:41 PM
discoman84
Jan 30, 2012 02:59 PM
wheelgarage
Jun 27, 2011 01:19 AM
