1999 discovery series 2 digital clock light
Old Mar 20, 2007 | 01:33 PM
rphotographer's Avatar
Default 1999 discovery series 2 digital clock light
the light is out in the digital clock,I have 2 questions.
how do you get the clock out to replace the blub and where can you get a new blub?
Thanks
Ralph
Old Mar 20, 2007 | 03:30 PM
okdiscoguy's Avatar
Default RE: 1999 discovery series 2 digital clock light
Pull out the cruise control button assembly below the clock. It should slide out easy. The clock was a little tricky for me, but you can just pry it out. Be Careful! The bulb on the clock does not come out of the base. There is a black plastic base that just turns a quarter turn and pops out. You can get a bulb at the dealer for around $7, but I think Atlantic British carries them too. Don't waste your time with regular auto parts stores, they will just try to pry out the bulb, break it, and then try to sell you something you don't need to replace it.
There are 4 panel retaining clips holding it in, The workshop manual was not very helpful on removing this. Someone else may have a trick or 2 to get it out. You can pull the switch assembly and the ashtray to reveal 4 screws holding in the drink tray. The WS manual says to remove it, but I didn't. Might make it easier.
Hope this helps! Good Luck
Jason
jneil
Sep 5, 2011 06:33 PM
tophur
Feb 12, 2008 03:22 PM
5206dj
Audio/Visual Electronics
Nov 22, 2007 09:35 AM
cryptic
Mar 13, 2007 05:03 PM
Jimbo
Aug 9, 2005 11:09 AM
