2” lift with 18” Wheels - What’s the right tire?
Old Jul 22, 2024 | 06:16 PM
  #41
DevGru's Avatar
Originally Posted by TimInNova
I've got a 2 inch lift and am running LT265/65 R18 Nitto Terra Grappler G2's and love them. No rubbing, great on and off road with amazing tread life.
Looks awesome! Thank you for the response. I sincerely appreciate it !!!!
Awesome looking Disco 2 !!!
Old Jul 23, 2024 | 07:51 PM
  #42
TimInNova's Avatar
PSA
Old Jul 25, 2024 | 09:16 AM
  #43
H Hill's Avatar
I have Nitto Terra Grapplers in size 275/65/18 with no rub. I have OME HD spings, which cause a 2" lift.
Old Jul 27, 2024 | 03:00 AM
  #44
DevGru's Avatar
I ended up getting 265/65/18 but I could have put a 295/70/18 with a slight cut to lower front rear plastic that would not be noticeable.
I went with the 265/65/18 because of tire weight and less work on engine and gears.
I appreciate the advice!
Old Jul 27, 2024 | 03:11 AM
  #45
DevGru's Avatar
Default 295/70/18 fits Disco 2 on a Terrafirma Medium 2” Lift
The 295/70/18 (34” tire) fit with a Terrafirma Medium 2” Lift !!! They made the vehicle sit A LOT higher. I tried just one AT tire at a tire shop when they did not have 275 and 285. Minimal rub in one area and that was front rear lower against plastic rocker which I cut have easily cut and not been noticeable.
I saw the weight of that tire at 69.2 lbs each! So I decided it was going to be way too much for the engine, transmission, and gears.
I ended up buying 265/65/18 in an aggressive 31” tread. They only weight 37 lbs each and ride nice. The spare even fit lifting it up to bottom two holes.
But check out these photos on that 34” tire. 2” lift! 2001 Disco 2
Old Jul 27, 2024 | 08:46 PM
  #46
Brandon318's Avatar
Originally Posted by Rich Spiess
Here is a pic of my 2002 Disco with a 2" lift and 265/65/18 Goodyear Duratracs. Very slight rubbing on the stock front bumper. Just had to trim a bit and trim the front inner fender liner. In my test fit my Arb number (not yet installed) clears it fine.
Aesthetically and proportionally I feel like the 2” lift is ideal for these. Great looking truck.
Old Jul 28, 2024 | 01:28 AM
  #47
DevGru's Avatar
I totally agree!
acg
May 11, 2015 10:20 PM
Yosemite Sam I am
May 31, 2014 07:49 PM
KlamathMatt
Feb 17, 2013 07:55 AM
GJgo
Tires
Jun 22, 2010 10:59 PM
bangkuaidiscovery04
Oct 11, 2009 01:15 AM
