2" or 3" Lift?
Old Mar 14, 2021 | 12:46 PM
Woodrow Ng's Avatar
3rd Gear
Default 2" or 3" Lift?
Hi guys,
I'm new to disco world and planning to make it as overlanding rig.
Do you guys need to add spacer for gearbox, control arm adjustment, etc. after 3" lift?
Do you guys have any recommendation for 2" or 3" lift?
Old Mar 14, 2021 | 05:04 PM
The Deputy's Avatar
Man, that looks mighty clean. Must have been garage kept. No sunroofs, the best.
For overlanding, 2" would be fine in my opinion. Might go with HD in rear, depending on storage compartments and sleeping platfprm weight. Went with medium on my first Dll, sagged a bit when loaded the extended trips.
Old Mar 14, 2021 | 10:34 PM
Frank4's Avatar
Originally Posted by Woodrow Ng
Hi guys,
Go with a 3”. I’ve had 2” and 3” and the 3” opens up so many options. Want bigger tires down the road, no problem. Find an ARB or steel bumper super cheap on Craigslist, no problem.
I’ve had 2” and 3”. The 3” is by far for versatile.
Old Mar 15, 2021 | 11:06 AM
XRAD's Avatar
I like my combo of 2" springs and 2" spacers....HD very firm without load..even with adjustable shocks...
Old Mar 15, 2021 | 11:28 AM
Woodrow Ng's Avatar
3rd Gear
Yeah, I was little surprised when i found this disco, single owner, 200k and all dealership records for $3k USD.
Old Mar 15, 2021 | 11:30 AM
Woodrow Ng's Avatar
3rd Gear
Do you need to change control arm, adjustment axle distance, brake line, etc. when you do the 3" lift?
Old Mar 15, 2021 | 11:38 AM
whowa004's Avatar
I would upgrade the front shaft regardless. I would not buy the cheap shaft from Lucky8.... and extended brake lines are cheap and easy and always a good idea. Good piece of mind if nothing else on a 20 year old truck.
SmokinV10
Sep 6, 2022 07:20 PM
Just For Fun
Jun 10, 2019 07:31 PM
skatelove303
Apr 25, 2011 10:32 AM
Chris-bob
Oct 8, 2010 09:53 PM
discolvr
Mar 31, 2009 10:06 PM
