2 inch lift info
Old May 16, 2012 | 09:27 PM
kman35ca's Avatar
Default 2 inch lift info
Do I need longer brake lines and Caster correcting bushings for the radius arms. I was told not for a 2 inch lift but would like to get some other opinions.
Old May 16, 2012 | 09:33 PM
That depends, if you go with a heavy load 2" lift but do not carry a heavy load then you will actually be higher than 2" and you may need those parts.
If you go with a medium load 2" lift and no load then no, you will not need them.
Heavy load (commonly called heavy duty) lifts are meant to be used with heavy loads, like a winch bumper and winch, rock sliders, heavy duty rear bumper, roof rack, loaded cargo area, loaded cargo rack, etc.
You can also get a light load 2" lift which is OEM weight rating but 2" of added height.
Old May 16, 2012 | 09:43 PM
kman35ca's Avatar
k right on. just wanted to make sure. Thanks dude
Joebern
Jun 21, 2011 05:09 PM
landunit
Dec 1, 2007 06:54 PM
johnnybob06
Nov 7, 2007 12:24 AM
morfa
Aug 27, 2006 01:22 PM
Kiwi Mike
Dec 26, 2004 06:31 AM
