2 inch lift question
Old May 21, 2012 | 12:47 PM
raul507's Avatar
Default 2 inch lift question
Did the TerraFirma 2inch lift about 3 months ago and I've had a few issues since. Was wondering if I could get some advice on the following;
1) With a 2 inch lift do I need to change the bushing to compensate for the lift.
2) Since the lift I have needed to replace both tie rod ends on the drag link (actually replaced the link and the other tie rod) due to play in the wheels. Could the larger tires and increased angle on the drag link due to the lift stress out the older components.
3) Since the lift I've developed a rhythmic thumping noise when turning left in traffic circles (it's Europe they're everywhere). Had the front end looked at and the shop couldn't pinpoint the issue. Any ideas where to start.
I know these hard to answer but any input would be appreciated. Thanks.
Old May 21, 2012 | 01:18 PM
How many miles on the truck?
No you should not have to replace any bushing because of the lift, unless they were bad to start with.
The lift did not cause the drag link ends to fail.
I would need more information to help with the turning thumps, other then to make sure your CV joint and both front hubs are still good.
Old May 21, 2012 | 01:39 PM
raul507's Avatar
Thanks for the quick reply Mike.
The truck is a 2003 Disco with 93k on the clock.
Good to know about the tie rod ends...either way they needed replacing.
Definitely don't doubt your advice but I could have sworn I'd seen something on the forum about having to adjust/shim/etc after a two inch lift or more.
Kind of at a loss with the thumping noise even after the shop I took it to stated they could produce the noise when driving (only turning left) but couldn't figure out exactly what the issue was. I'm assuming it's CV joint or hub but when the shop couldn't figure it out ????
Old May 21, 2012 | 02:16 PM
If you want to play 20 questions, send me your number and I'll walk you thru this.
svntsvn
Jan 16, 2015 07:59 AM
Joebern
Jun 21, 2011 05:09 PM
landunit
Dec 1, 2007 06:54 PM
morfa
Aug 27, 2006 01:22 PM
Kiwi Mike
Dec 26, 2004 06:31 AM
