2 issues start noise and p0340
Hey guys with your help ever since I changed my serpentine belt and pulleys. I have a squeal sound when I cold start the engine. It is for a half second
and also I have gotten error code p0340
what can be causing the squeal and code there any relation ?
thanks
thanks
Well, code PO340 is cam sensor related...and it harness is in the same general area as belt. Maybe you snagged or dislocated sensor plug while changing belt? Also, check tensioner and pullies, known to go bad often, and will squeal. Old belt may have been slipping enough or worn that it didn't cause pullies/tensioner to make noise...but new belt is gripping pullies better/tighter and causing noise now.
