2 issues start noise and p0340
Old Jul 10, 2021 | 11:43 AM
Oshawa_D2's Avatar
Default 2 issues start noise and p0340
Hey guys with your help ever since I changed my serpentine belt and pulleys. I have a squeal sound when I cold start the engine. It is for a half second
and also I have gotten error code p0340
what can be causing the squeal and code there any relation ?
thanks
Old Jul 10, 2021 | 12:02 PM
XRAD's Avatar
are you sure you have the belt on correctly? it can be put on in wrong config and is still tight....
Old Jul 10, 2021 | 02:50 PM
Oshawa_D2's Avatar
yes I been driving the truck now with no issues
this is how I put the belt on
Old Jul 11, 2021 | 05:48 AM
The Deputy's Avatar
Well, code PO340 is cam sensor related...and it harness is in the same general area as belt. Maybe you snagged or dislocated sensor plug while changing belt? Also, check tensioner and pullies, known to go bad often, and will squeal. Old belt may have been slipping enough or worn that it didn't cause pullies/tensioner to make noise...but new belt is gripping pullies better/tighter and causing noise now.
Old Jul 11, 2021 | 11:59 AM
Oshawa_D2's Avatar
I changed all the pulleys also actually including the tensioner. I can look for the sensor plug the error message hasn’t come up in the last two days however. Which side is the sensor plug on?
Oshawa_D2
Jul 2, 2021 09:06 PM
PowerRov
Oct 25, 2018 12:00 PM
RegT
Oct 18, 2015 08:09 AM
Disco2Fever
Apr 16, 2009 09:45 PM
mimimi
Jul 26, 2007 01:26 PM
