2000 D2 - every gear is like neutral except P. Does not Go! Help needed.
Old Apr 9, 2015 | 09:02 AM
  #41
Motorhead1's Avatar
I would definitly put a used tranny in too. Kinda wierd that there cheap and plentiful....for a Rover.
Don't put your ATF in until the tranny is installed. Get everything ready (have the old tranny hanging with a couple bolts) then go rent a tranny jack for a day, do the swap.
Old Apr 9, 2015 | 09:44 AM
  #42
drowssap's Avatar
if you go the used route, when your changing the filter you can add a D1 oil pan and dip stick
Old Apr 9, 2015 | 09:46 AM
  #43
Racer X's Avatar
Originally Posted by KRAMER
Do you second the idea of putting the used transmission in Racer X?
Used known good is better than used known broken.
Also, make sure you fill the torque converter with ATF before you install it, lest you burn it up with the first turn of the key.
Old Apr 9, 2015 | 12:48 PM
  #44
KRAMER's Avatar
Well, there she is.... that's what $350 gets ya at the local salvage parts store. Tried to get at the truck it came out of but it was gone...
Attached Thumbnails 2000 D2 - every gear is like neutral except P. Does not Go! Help needed.-20150409_120031.jpg   2000 D2 - every gear is like neutral except P. Does not Go! Help needed.-20150409_120040.jpg   2000 D2 - every gear is like neutral except P. Does not Go! Help needed.-20150409_120048.jpg   2000 D2 - every gear is like neutral except P. Does not Go! Help needed.-20150409_120055.jpg
Old Apr 9, 2015 | 12:56 PM
  #45
Racer X's Avatar
Swap your existing shift linkage arm onto the XYZ switch on the new transmission before you install it.
Then, sell your old XYZ switch and recoup 1/2 the cost of your new transmission. lol
  #46
abran's Avatar
Looks the the linkage lever at the XYZ switch is bent, you will need to straighten that out.
Install new trans, If the XYZ switch is good, sell your old one off the trans that is no good and recoup some of your cash.
Going rate it $100 ish.
Old Apr 9, 2015 | 12:57 PM
  #47
abran's Avatar
Originally Posted by racer x
swap your existing shift linkage arm onto the xyz switch on the new transmission before you install it.
Then, sell your old xyz switch and recoup 1/2 the cost of your new transmission. Lol
beat me to it!
Old Apr 9, 2015 | 12:59 PM
  #48
Motorhead1's Avatar
Your in now!!
Old Apr 9, 2015 | 02:20 PM
  #49
KRAMER's Avatar
Absolutely! The truck shows PRND321 just fine so I'm betting the switch is fine and the shift arm on the truck is also beautifully straight! I will be trying to figure out what I can sell off this thing for sure to make my money back. I'm the cheapest guy I know and apparently the luckiest as well... Just picked up my last check from the shop this morning and have to sign in at the hall! Yay union..... I guess I have time to work on the "Drover" as my little one calls it. He hates that it don't go. Its basically his truck at 5..
Old Apr 9, 2015 | 02:22 PM
  #50
KRAMER's Avatar
How do I put the cool little signature quote at the end of my posts like you guys all have?
Like 69 blazer
---- land rover
----- harley....
